Foundation Library Project Wizard
I want to dado & screw divisions, fixed shelves, nailers, and drawer stretchers.  But I don't want to dado tops and bottoms.  I believe the proper method for accomplishing this is to open the Project Wizard, and select Dado & Screw under Default Construction Method, then select Screw under Construction Method Top and Construction Method Bottom.  Unfortunately, this doesn't work.  I get Dado and Screw for everything, no matter what is in the Construction Method Top and Construction Method Bottom.
In fact, I have just tried setting Default Construction Method to None, then Construction Method Top and Contruction Method Bottom to Dado & Screw, but they both still come out as none.  It looks like Construction Method Top and Construction Method Bottom don't actually do anything at all.
Am I missing something?
