Foundation Library Setup
I am looking at starting the process to convert to the Foundation library and have a couple questions on the setup.
  1. When applying your standard global and wizard values (i.e. construction methods, tool numbers), should we be creating a new wizard and global or should we just put our settings into the default Project Wizard and Unitless Global Default. We want to insure that we can still utilize the updates without having to go and change these settings every time an update comes out.
  1. Similar to the global and the wizard. We have a specific naming convention for sheet goods for the Biesse system. Should we be creating a new cutpart file component or should we be creating folders specific to our naming convention in the default.
