Hi,
We're starting out on the new library an are having issues with Wizards 'reverting back to default' when selecting 'Default Drawers'.
If we change the 'Default Drawers' as per 'Image A' (attached) it works when you redraw however when you restart MV and redraw, the drawers revert back to the default.
If we make the same change via Image B attached then it works and doesn't revert after a MV restart.
Can someone please shed some light on this. Am I doing something wrong? Should we avoid making spec group changes from 'Image A'?
FYI my spec group is a copy of the unitless spec group because I wanted to make use of the Wizards.
Library V22.0317
