Global Machine Token edit
I'm looking for a method to edit a standard machine token and have it affect all parts that utilize it.
The token in question is "ROUTE5[Finished End Scribe]"
The Offset is hard-set to "L," which has caused us some grief.
We want our added scribe to be 1/4", but our default routing tool is a 1/2" bit (the same tool for Nesting), so the scribe route is 1/2" wide instead of 1/4", this causes it to undercut our nailers and the dowel holes are on 1/8" away from the rabbets on finished ends
I do not see a way to change this globally other than to enter every product workbook and make the change manually!?!
Any help would be appreciated.
