Global Over Sizing Parameter
I was wondering if anyone else has set up a global over sizing parameter? Basically a switch in the Wizard that turns on over sizing of components to allow for scribing to walls, ceilings and floors. When turned off the model shows the ‘scribed’ finished size flush with walls etc. And when turned on it shows the actual cut size penetrating walls, floors etc. This can also be used for small components that are too small to be cut on a cnc so in turn are oversized to meet the minimum size requirement to hold down with vacuum. Automation of a sticker comment with “oversize” and “finished size” allow the fabricator or installer to know what to manually cut the component to.
I know there are already a few negative material ‘ghost’ part options but I think there’s room to fine tune this in the library.
