This has been said before by myself and others but it sure would be nice if the help text could word wrap and not disappear. Ever since it was changed to the bubble from the original red text at the bottom that stuck, it has been a nuisance for longer help text which is sometimes necessary.
Probably would be best to make it user definable with a parsed parameter at the end of the help text, designated by a special character. One for how many seconds to have it appear or a way to indicate permanent upon hover, and another for how many lines/rows to display or something. Or maybe a special character you can insert within the body of the text at certain points to define when to wrap.
To take it a step further, it might also be good to rework the help images as well. It has also been a bit clunky for a while that the image appears toward the bottom right of the prompts screen. Depending on how many check boxes you have and how big you have the prompts screen set it cannot display properly. How about we move the image to within the same help text bubble. That they display together. Then for combo box images it’s just an image in a bubble.
Food for thought, at any rate I think it might be time to give these some attention. Vote if you agree.
