Here are most of the A&M brackets
A while ago, I contacted A&M about adding their brackets to our library and sharing them with the MV community. Jared Ingold at A&M kindly sent me a number of drawings to work from. I have the 3D models (drawn in metric for inclusivity) finished but still need to finalize the 2D plan/elev/sect drawings.
None of the hardware have machine tokens yet, because I'm playing around with a large lookup table.
Here's what I've got so far:
STANDARD
CONCEALED
EXTENDED CONCEALED
CONCEALED FLAT
EXTENDED CONCEALED FLAT
HYBRID & HD HYBRID
SHELF & VANITY
CLEAT & ISLAND
5x8 Standard Bracket
C-9 1in Concealed Bracket
EC-9 1in Extended Concealed Bracket
CFLAT-9 1in Concealed Flat Bracket
ECFLAT-9 1in Extended Concealed Flat Bracket
HYB-9 1in Hybrid Bracket
FS-6 Floating Shelf Bracket
CLT-28 2in Cleat Bracket
8x12 Standard Bracket
C-12 1in Concealed Bracket
EC-12 1in Extended Concealed Bracket
CFLAT-12 1in Concealed Flat Bracket
ECFLAT-12 1in Extended Concealed Flat Bracket
HYB-12 1in Hybrid Bracket
FS-9 Floating Shelf Bracket
CLT-44 2in Cleat Bracket
12x12 Standard Bracket
C-15 1in Concealed Bracket
EC-15 1in Extended Concealed Bracket
CFLAT-15 1in Concealed Flat Bracket
ECFLAT-15 1in Extended Concealed Flat Bracket
HYB-15 1in Hybrid Bracket
FS-12 Floating Shelf Bracket
CLT-90 2in Cleat Bracket
12x18 Standard Bracket
C-18 1in Concealed Bracket
EC-18 1in Extended Concealed Bracket
CFLAT-18 1in Concealed Flat Bracket
ECFLAT-18 1in Extended Concealed Flat Bracket
HYB-18 1in Hybrid Bracket
HS-6 Hidden Shelf Bracket
ISLBAR15 Island Bracket
15x15 Standard Bracket
C-9 2in Concealed Bracket
EC-9 2in Extended Concealed Bracket
CFLAT-9 2in Concealed Flat Bracket
ECFLAT-9 2in Extended Concealed Flat Bracket
HYB-21 1in Hybrid Bracket
HS-9 Hidden Shelf Bracket
ISLBAR34 Island Bracket
15x21 Standard Bracket
C-12 2in Concealed Bracket
EC-12 2in Extended Concealed Bracket
CFLAT-12 2in Concealed Flat Bracket
ECFLAT-12 2in Extended Concealed Flat Bracket
HYB-24 1in Hybrid Bracket
HS-12 Hidden Shelf Bracket
ISLBAR40 Island Bracket
18x18 Standard Bracket
C-15 2in Concealed Bracket
EC-15 2in Extended Concealed Bracket
CFLAT-15 2in Concealed Flat Bracket
ECFLAT-15 2in Extended Concealed Flat Bracket
HYB-9 1.5in Hybrid Bracket
IS-6 Invisible Shelf Bracket
ISLBRKT Island Vertical Bracket
18x24 Standard Bracket
C-18 2in Concealed Bracket
EC-18 2in Extended Concealed Bracket
CFLAT-18 2in Concealed Flat Bracket
ECFLAT-18 2in Extended Concealed Flat Bracket
HYB-12 1.5in Hybrid Bracket
IS-9 Invisible Shelf Bracket
SF-6 2in Surface Flat Bracket
21x21 Standard Bracket
C-21 2in Concealed Bracket
EC-21 2in Extended Concealed Bracket
CFLAT-21 2in Concealed Flat Bracket
ECFLAT-21 2in Extended Concealed Flat Bracket
HYB-15 1.5in Hybrid Bracket
IS-12 Invisible Shelf Bracket
SF-9 2in Surface Flat Bracket
24x24 Standard Bracket
EC-24 2in Extended Concealed Bracket
CFLAT-24 2in Concealed Flat Bracket
ECFLAT-24 2in Extended Concealed Flat Bracket
HYB-18 1.5in Hybrid Bracket
IS-15 Invisible Shelf Bracket
SF-12 2in Surface Flat Bracket
24x29 Standard Bracket
EC-30 2in Extended Concealed Bracket
HYB-21 1.5in Hybrid Bracket
RV-18 Raised Vanity Bracket
SF-15 2in Surface Flat Bracket
29x35 Standard Bracket
HYB-24 1.5in Hybrid Bracket
RV-21 Raised Vanity Bracket
ST-10 2in Stair Tread Bracket
HD HYB-18 1.5in Hybrid Bracket
HD HYB-24 1.5in Hybrid Bracket
I have not included the Adjustable Shelf Brackets because we never use them. I'll probably add them later just so it's a complete catalog.
Within the .7z (can't get standard zip file under 20.012mb) file is the Graphics>Hardware folders and the .sdf to import.
This is what all of just the Standard Brackets look like attached to a countertop:
