Hinge Cup Pocket Routes
My hinge cups are set to be machined as a pocket route but when the data is sent to WoodWop these operations are coming in as Vertical Routing.  I want to have a specific router bit (3/8" Compression) to route all my pockets including the hinge cups.  I have set the 3/8 bit to be to default pocketing tool within the machining global setting and also within the tool file.  Since this is being brought into WoodWop as a vertical routing operation and not a pocket im not getting the specific tool that i want used.  How do i have the hinge cups actually come in as a pocket?  Or how to force the specific tool to be used for hinge cups so i dont have to change these settings at the machine?
