Question,
looking for the way to adjust the hinge plate offset from the front in the foundation. I did find formulas in the "S" workbook for every door style in column K. The formula is =IF(IS_Face_Frame,0,M2U(37,G!Accuracy)+G!Door_to_Cabinet_Gap). I need to adjust the 37mm portion as production is always max out hinge adjustment forward for Salice hinges and plates.
Is there a simpler way to adjust beside updating 60 lines of formulas? I do not want to change my door to cabinet gap as that will cause issues with drawers and drawer faces not having machining for set screws and adjusters.
