Hinges
I have just change a corner door hinge machining from a routered 35mm hole to a bore 35mm hole.(Blum Bi-Fold 60deg Knock-in).
I was wondering do I need to change the name in workbook designer so that it wont revert back when I update the program.
Also is there a way to copy the hinge and rename as then I would have both styles of machining available.
I have only change the hinge at project level at this point in time.
Cheers Scott
