Hnager Notch when there is a filler
When I have a row of upper cabinets, the hanger notch is fine. But when I add a filler in the prompts and change the filler height, the hanger notch also changes. I can fix it in the part properties, but I don’t want to have to check that every time I adjust a filler.
Is there a variable or setting that stops the hanger notch from changing with the filler height?
