Face 5 machining is completed on our CNC nested sheet. Some parts are going to a Pod and Rail for Face 6 machining. Currently. when Horizontal Boring is required, code is combined with Face 5 code for single part machining. Face 5 has already been completed. Face 6 is actually Single Part machining.
Need the ability to combine HBORE code with Face 6 code (in the part image as well), as both are considered to be Single Part Machining.
Additionally, reference machine field registration point as it relates to M-point in the image to avoid machine operator confusion.
Check box in IPP to combine to H Bore and Face 6 does not work, and could be a bug, as mentioned in Q4 Road Map meeting.
