Microvellum Knowledge Network
How can I add a new Project Wizard Variable?
Hi, I am trying to set up a new drawing template in Microvellum, and I need to display some information in the 'Specification' page. I can set the 'Default Toe Kick Height' in "Project Properties=>Project Wizard=>Project Setup", because there is already a variable called 'Default Toe Kick Height'. If I would like to set another variable called 'Bench Top Height', what should I do?
Another problem is similar, I have to display all appliances in the 'Specification' page, and is there anyway that I can add a variable called 'Rangehood' and add some rangehood options in the project wizard, when I start a new project, I can select the appliances from library and display them in the 'Specification' page.
Thank you very much.
        Google Review
