How Can I Change the Angle of an Extruded Shape's Ending Edge?
Hi all, the first pic is my 2d drawing of this circular desk I'm trying to extrude. The second pic shows what I'm trying to achieve after extruding. I broke my desk out into 3 separate construction paths because Path 2 needs different studs. After extruding, I moved all 3 of my extruded construction paths to connect to each other. By doing so, I now need to somehow make my Path 1 plates fully meet and follow the angle of Path 2's plates (see pic 2) because it ends my Path 1 plates at a different angle than I need them to be (see pic 3). How can I change the angle where my Path 1 extruded plates end to meet the angle of Path 2's extruded plates? I've tried the extruded tools but none are helping me with this issue. Any insight would be appreciated!
TLDR: How can I change the angle where my extruded plates end to meet the angle of my other path's extruded plates?
