How to add edge band for a sub-assembly of a sub-assembly?
Using a base cab with waste bin pullout.  The work order shows the front panel has no edge band (EB) on Width 2.  I'm used to adding EB in the subassembly under Parts.  But in this case, the finished face is in the subassemblies of the subassemblies.  That menu doesn't have EB options.  Where is this option found?
