Import Hardware (with machine tokens)
We currently use the import material feature to keep all of our material organized. This is super useful when changing or adding material as it's just an excel file and we can easily copy and paste names and values. I'm running into an issue where we want to change the size of our hinge holes. I know you can import hardware (I've never used that feature though) but you can't import hardware with the associated machine tokens? For example in my case I want to change all of our 8mm holes on our hinges to be 8.2. Right now I have to manually go into EVERY SINGLE HINGE and replace that value in the machine token. It's slow and just not an efficient way to make wholesale changes to our hardware like that.
It would be nice if the import function for hardware would allow you to also import the related machine tokens. That way I could easily just find and replace the 8 and change it to be 8.2.
