Inside corner relief cut ?
 I have some custom parts that I am needed to add a relief cut out  at the inside corners to tightly fit another part in the corner. Currently we are cleaning out the inside corners manually and I am wondering is there a machining token we could use instead to cut the corner relief out on the CNC?
