Internal drawer with faces material indicator
Hi,
Does any one else use many internal drawers with faces & is having to manually go into the subassembly to change to internal drawer faces to white melamine, same as the carcass?
We do many wardrobes that have internal drawers with faces, and we find that when you insert internal drawers, the material indicator looks at the finished face material.
You must remember to go in and manually change through the sub-assembly all the drawer front faces and the side fillers to be white melamine as the internal carcass.
You would rarely have the internal drawer faces the same colour as the door's external face material.
It would be a huge time saver and stop internal drawer faces from being cut out of finished face material.
A material indicator or a prompt, so by default, the internal drawer faces are the same as the internal carcass material.  Something like the shadow rail material indicator.
Not sure what the best solution to this is.
Does anyone have any good ideas?
