Is there a way to set up parametric Multi-Pass tooling
I'm currently setting up multipass tooling for a new set of compact laminate/solid surface cutters (1 roughing, 1 finishing). The problem is we have 6 separate thicknesses of these materials in our library plus more we haven't used yet and i would rather not have to create a new multi-pass tool for each one if possible. It doesn't look like i can set up a step/incremental step cutter as they don't allow the use of different cutters, is there a way i can set up a multi-pass tool with multiple cutters that adds extra passes determined by the thickness of the material? Is it possible to use Step tools within Multi-pass tools?
