King Slide Undermount and Ball Bearing Slides Now Available in the Foundation Library
Microvellum is happy to announce the addition of brand new hardware from King Slide into the Foundation Library catalog: the 1X97 and 1X97F bottom-mounted slides from King Slide's SIMLEAD wood drawer system, as well as 6 new King Slide ball-bearing slides (the 3J89, 3M89, 3J01, 3M01, 3J52, and 3M52(G) will be available for use in client projects from library version 24.0119 and onward. To access these products, simply select them in a product using the product prompts or Hardware Material Wizard.
To download the totality of King Slide’s hardware products that have been added to the Foundation Library, visit the Microvellum Foundation Library Supplemental Downloads page, or update to the latest library version.
Please contact Microvellum support with any questions or issues you may encounter while installing or using.
King Slide SIMLEAD Wood Drawer Bottom Mount Slides
King Slide's bottom mounted Slides for the SIMLEAD Wood Drawer System have now been integrated into the Foundation Library, available for use in both Frameless and Face Frame options. The slides have a built-in soft close feature, 8-way adjustment, load bearing capacities of 40 KG (88 lbs.), and slide lengths varying between 250-600 mm (1X97)/229-533 mm (1X97F).
King Slide 1X97 (40 kg, Soft Close)
Slide Lengths
  • 250 mm
  • 300 mm
  • 350 mm
  • 400 mm
  • 450 mm
  • 500 mm
  • 550 mm
  • 600 mm
King Slide 1X97F (40 kg, Soft Close)
Slide Lengths
  • 229mm
  • 305mm
  • 381mm
  • 457mm
  • 533mm
King Slide Ball Bearing Drawer Slides
6 of King Slide's full extension ball bearing slides have been added to the Foundation Library, with variations in features, load bearing capacities varying between 34-45kg (75-100 lbs.), and 8 different length options:
  • The 3J01 and 3M01 are standard ball bearing slides suited for home cabinets, drawer boxes, storage, and file drawers.
  • The 3J89 and 3M89 slides are ball bearing slides suited for nearly any cabinet drawer application, sporting a built-in push-close feature. respectively.
  • The 3J52 and 3M52(G) are ball bearing slides with unilateral applications, featuring built-in soft-closing features.
All 6 slides come in the following options for slide length:
  • 250 mm
  • 300 mm
  • 350 mm
  • 400 mm
  • 450 mm
  • 500 mm
  • 550 mm
  • 600 mm
Slide Option
Slide Features/Load Capacity
Microvellum Image
King Slide 3J89
34kg (75lb) Light Duty - Push Open
King Slide 3M89
45kg (100lb) Medium Duty – Push Open
King Slide 3J01
King Slide 3M01
King Slide 3J52
34kg (75lb) Light Duty – Silent Soft Closing
King Slide 3M52(G)
45kg (100lb) Medium Duty – Silent Soft Closing
