King Slide SIMLEAD and ULEAD Now Available in the Foundation Library
Microvellum is happy to announce the addition of two new lines of hardware from King Slide into the Foundation Library catalog: the King Slide SIMLEAD drawer system and ULEAD drawer slides will be available for use in client projects from version 23.1010 and onward. To access these products, simply select them in a product using the product prompts or Hardware Material Wizard.
Please contact Microvellum support with any questions or issues you may encounter while installing or using.
King Slide SIMLEAD
King Slide’s Ultra Slim 13mm Sides drawer, integrated into the Foundation Library with the full array of customization options available for use in client projects. The SIMLEAD comes in 4 different drawer height options, with 6 options available for the metal drawer slides, push to open, soft close, and tilt adjustment configurations, and drawer lengths between 270-600mm, all with load bearing capacities of 40/70kg (88/154 lbs.) and in 4 different color finishes (black, grey, silver, and white). Synchronization between push to open and soft close is available for 86 series models, and inner drawer options are fully enabled for use.
Colors:
  • Black
  • Grey
  • Silver
  • White
Drawer Heights:
  • MABA (97 mm)
  • MACA (138 mm)
  • MADA (185 mm)
  • MAEA (249 mm)
Metal Drawer Slides:
  • 1L86 (70 kg, Push to Open + Soft Close)
  • 1N86 (40 kg, Push to Open + Soft Close)
  • 1L95 (70 kg, Soft Close)
  • 1L96 (70 kg, Tilt Adjustment + Soft Close)
  • 1N95 (40 kg, Soft Close)
  • 1N96 (40 kg, Tilt Adjustment + Soft Close)
Drawer Lengths:
  • 270
  • 300
  • 350
  • 400
  • 450
  • 500
  • 550
  • 600
Options:
  • Push to Open Synchronization Rod (Available with the 86 Series drawer slides)
  • Inner Drawer
ULEAD Drawer Slides
Undermount Drawer Slides for both frameless and face frame applications.
King Slide’s undermount drawer slides, created for both frameless and face frame applications. The ULEAD drawer slides are concealed runners with options for push-open and silent soft-close mechanisms, in addition to options for standard, 4-way, and 6-way adjustment. The Foundation Library has added the ULEAD drawer slides in both applications with 8 different models for both frameless and face frame applications (1A89, 1B89, 1A68, 1B68, 1J68, 1K68, 1J69, and 1K69), with load bearing capacities of 34-45 kg (75-100 lbs.) and slide lengths between 250-600mm.
Frameless Slide Options
  • 1A89 34 kg(75lb) Push Open
  • 1B89 34 kg(75lb) Push Open
  • 1A68 45 kg(100lb) Silent Soft Close
  • 1B68 45 kg(100lb) Silent Soft Close
  • 1J68 45 kg(100lb) 4-Way Adjustment Silent Soft Close
  • 1K68 45 kg(100lb) 4-Way Adjustment Silent Soft Close
  • 1J69 45 kg(100lb) 6-Way Adjustment Silent Soft Close
  • 1K69 45 kg(100lb) 6-Way Adjustment Silent Soft Close
​Frameless Slide Lengths
  • 250 mm
  • 300 mm
  • 350 mm
  • 400 mm
  • 450 mm
  • 500 mm
  • 550 mm
  • 600 mm
Face Frame Slide Options
  • 1A89F 34 kg(75lb) Push Open
  • 1B89F 34 kg(75lb) Push Open
  • 1A68F 45 kg(100lb) Silent Soft Close
  • 1B68F 45 kg(100lb) Silent Soft Close
  • 1J68F 45 kg(100lb) 4-Way Adjustment Silent Soft Close
  • 1K68F 45 kg(100lb) 4-Way Adjustment Silent Soft Close
  • 1J69F 45 kg(100lb) 6-Way Adjustment Silent Soft Close
  • 1K69F 45 kg(100lb) 6-Way Adjustment Silent Soft Close
Face Frame Slide Lengths
  • 229 mm
  • 305 mm
  • 381 mm
  • 457 mm
  • 533 mm
