Label Alignment Issues
Hello All,
I am having troubles with label alignment when using 4x1 labels.
The Designer allows me to change the margins, but it will not allow me to change column spacing.
When going to change the column spacing it will only accept numbers under .3
Oddly the Column Space itself is set to 0 by default, changing this does nothing.
The Column Count also does not appear to work, setting it to 1 still shows 2 columns but resolves an odd ghosting issue in the print preview.
Ghosting with columns set to 2
