Ladder Toekick
We use a Ladder Toekick for our cabinet bases. We are using ToolboxBSB with the Foundation Library 26.0220. Why was the ladder toekick that was in the Component Library taken out of the Foundation Library? I need the one from the Component Library back, or tell me how to change the one in the Foundation Library (Toe Kick Base) to look like the Component Library (Stretcher Frame)
I need the "Cleats" to run left to right not front to back, and we also need to be able to inset the
"Sleepers" on the ends for scribes. this also means the "Sub Back" and rear "Cleat" will also need its length to change accordingly.
I have attached a PDF file the top drawing is what we need the Toe Kick Base to be able to do.
