Does anyone know where to find the machine tokens for the Latch Timberline CompX Double Door in the Foundation Library? This latch is not listed in the hardware library. I did find it in the "H Look Up Table" under Secondary locks but it only lists the lock positions.
I need to change the bore diameter from 5mm to 2mm for small wood screws.
