LIBRARY ISSUE - NAILERS
Request to Fix ongoing Library Issues with Nailers.
Default Construction Method <Screw>
Default Construction Method <Dowel>
Tops/Bottoms/Fixed Shelves all use dowel at Finished Ends except Nailers.
The nailer has no machine tolken at finished end.
Why would all other parts work as expected except nailers? Shouldn't this be as all others, Dowel at FE and Screw at unfinished ends. Assuming that the construction method is screw.
