Can we add a field into the materials editor to assign a render finish to a sheet stock. This will give us the ability to set our render colors with our material information, and if the client changers a color late in the build we can change both on the same window, this means the colored render will adjust with the product when it is redrawn. This will also help with work flow as the colors can be set in the beginning of the project and if there is a panel assigned to the wrong material for any reason it will be clear in the render.
