Looking to nest Parts with panel border properties
Hello,
Going to try and explain this the best I can, hopefully it makes sense..
When I manually add a sheet using "nest editing & 2D machining tools", add my parts/machining, and then process, it does not process like it would if I use "create a new work order from drawing"
When using both "create new machining instructions & gcode from drawing" & "update existing machining instructions" Microvellum does not apply the purple line which tells the CNC to double pass all parts.
Instead, the CNC cuts each part, all in one pass.
I have attached the nested examples and "Machining Properties" per line.
Basically looking to cut all parts nested as a “panel border” using "nest editing & 2D machining tools"
Thanks!
