Hi,
I'm wondering if there is a way to make the Dado machine token draw only? We use FF Dado to Fixed Shelves/Vertical Bays, however production doesn't want the CNC to cut that Dado... they have another machine to do it.
Is there a way I can set it to Machine Only, or do I just have to go and turn off the token completely. Visually it helps a little, however it causes an error that pops up and wont "stay hidden". As a temp fix I used a tool that doesn't exist. I was hoping the stay hidden would work, but its not. Maybe there is a draw only method for this token?
Thanks,
-James
