Machine Token fail safe
Is it possible to create a formula or global to essentially "mirror" the machining as a fail safe if the selected machining edge is either edge 1, 2, 3 or 4? Can this be accomplished with machine point? Not finding any variables to use. We would like the machining to be reversed or mirrored if a 2 sided panel needs flipped. I can mirror the part but then the machining edge has to be repicked. Currently as far as I know there is no way to select from edge 1 to edge 3 after mirroring.
