Machine tokens compensate to wrong side
Recently discovered the ROUTEDHOLE machine token on our hinges creates paths that are left compensated. Also noticed that CUTOUT token when applied to parts will generate paths with the router on either side. Those particular tokens happen not to have compensation fields. Is there a way of making sure the router stays to the right of inside paths?
