How would i make the saw on our Biesse machine cut last? I use it to trim the offcuts into a sensible handling size and not have silly shaped pieces, however since ive been doing this it uses it fairly on in the cutting process which has led to a few small slithers to fall off down the side of the machine. The saw blade is used for nothing else so how do i absolutely make it cut last? Preferable one and done setup but i'm happy to force it when nest editing somehow, but i dont want to go round clicking "route priorities" on every route, thats too much, if i understand that mechanic correctly?
