Hi.
I'm in the process of updated our library to the latest edition and have noticed that the master cabinet's name, now is formulated and is reading back at Base 1 Door Left.
After comparing it with the actual Base 1 Door Left from the latest library, there isn't any difference that I can see between the two. Both have 492 lines in the prompts with the only difference that I can see is the LibraryName hidden prompt of the master cabinet is, master cabinet.
When comparing the two from my old library, there is a difference. 452 lines in prompts for the master cabinet and 328 lines in the prompts for base 1 door.
Can anyone confirm if this is correct? Is the new base 1 door simply a copy of the master cabinet now?
