Metafile Flatshot tokens
Hello,
Hoping there is someone out there with experience using the inbuilt Flatshot token (not the autocad command) to produce 2D product drawings.
I have a tabletop product that is made up of smaller tops joined together. Each smaller top is a subassembly. The product draws a flatshot of the entire table, then each subassembly will draw its own flatshot for a more detailed view of each section.
I am using Parameter 4 of the flatshot token to specify the area of each section
https://community.microvellum.com/portal/en/kb/articles/microvellum-flatshot-token-reference#Parameter_4_-__MINIMUM_BOUNDING_BOX_______MAXIMUM_BOUNDING_BOX_POINT
My problem is that the positioning of the flatshots are inconstant.
In the attached screenshot you can see that parts 4,6, and 8 are positioned incorrectly, the rest are correct.
I have gone over my formulas many times and can't see a reason for this. Also the Y values of flatshots 2,4,6, and 8 are identical.
I would expect part 2 to be positioned incorrectly as well, as there is nothing differentiating it from 4,6, and 8.
I can formulate this out (if part # = 4 or 6 or 8.....) but i don't think i should have to, i can't see why 2 would work as intended but 4,6, and 8 don't.
Anyone have any thoughts on this?
Thanks.
