Material Pointers Not Automatically Updating Existing Cabinets When Changing Specification Groups – Microvellum 2026
Software: Microvellum 2026
Build: 26.1.723.641
Library: Microvellum Foundation Library 25.11.21
Issue Description
I'm experiencing an issue with material assignments in existing cabinets when switching between Specification Groups.
I created a Specification Group called PL1 FULL GREEN, with the appropriate Material Pointers assigned to 0_75 U604 ST9 Reed Green.
However, when I assign this Specification Group to existing cabinets, the materials displayed under Product Prompts → Material Options do not automatically update.
For example, an existing Upper Open cabinet continues to display H1715 ST12 Parona Walnut for the top, bottom, sides, back, and adjustable shelves, even though its Specification Group is set to PL1 FULL GREEN.
Interestingly, the edgebanding materials correctly display Reed Green.
Troubleshooting Performed
  1. Verified the material assignments within the Specification Group and confirmed that the relevant Material Pointers are associated with Reed Green.
  2. Verified that the Room Properties reflect the intended material selections.
  3. Assigned PL1 FULL GREEN to an existing Upper Open cabinet (item 1.49).
  4. Recalculated and reopened the cabinet. The material prompts continued displaying Parona Walnut.
  5. Opened Product Prompts → Material Options, clicked the material selection button, and manually selected the appropriate pointer, such as Upper_Bottom.
  6. The material immediately changed to Reed Green.
  7. Saved the cabinet, recalculated, and reopened it. The manually selected material remained correct.
Result: Manually selecting the appropriate Material Pointer works and survives recalculation. However, assigning a different Specification Group does not automatically replace the existing material assignments in the product prompts.
Additional Observation
In the Product List, I noticed that existing cabinets can have different Specification Groups assigned, such as PL1 Grain v1 and PL1 FULL GREEN.
Changing the assigned Specification Group alone does not appear to reset previously assigned materials.
This suggests that some material prompts may retain their existing material selections instead of dynamically referencing the corresponding Material Pointers.
I have also reviewed the distinction between Project Specification Groups and Library Specification Groups, but the existing cabinet prompts still require manual correction.
Expected Behavior
Ideally, I would like to:
  • Configure material assignments centrally through Specification Groups.
  • Change a cabinet's Specification Group and have its material assignments update accordingly.
  • Remove existing manual material overrides and restore the appropriate library-defined Material Pointers.
  • Apply these changes to multiple existing cabinets without modifying each product individually.
  • Preserve cabinet dimensions, construction options, hardware selections, and other customizations.
Questions for the Community
1. Is there a built-in function to reset material prompts to their original library-defined Material Pointers?
2. Can Specification Group material assignments be reapplied to multiple existing cabinets in bulk?
3. Is there a specific library setting that controls whether material prompts use fixed Sheet Stock selections or dynamic Material Pointers?
4. What is the recommended workflow for changing materials across an existing room or project without manually editing every cabinet?
I'm working with a room containing numerous cabinets, so manually selecting every material pointer for every product is not a practical long-term solution.
Any guidance on the correct workflow, library configuration, or available bulk-update functionality would be greatly appreciated.
Thanks in advance!
Jonatas Melo
