Hello all,
I'm Peter Turšič, Principal and
Lead Microvellum Engineer at Tursic Millwork Solutions, LLC (Georgia). I work
as a subcontractor for shops that need engineering capacity.
Experience (21 years)
- 19.5 years creating shop
drawings, processing jobs, and building Microvellum products and product lines
- 15 years setting up and
managing Microvellum libraries for shops
- 1.5 years on the shop floor
building cabinets, helping build custom millwork such as reception desks and
nursing stations, and running CNC equipment
I engineer with the build in mind,
because I've built it.
Services
- Shop drawings/submittals for
architectural casework and millwork
- Microvellum production engineering
and CNC cut files
- New product development in
Microvellum
- Microvellum library setup,
cleanup, and management
- Microvellum report customization:
reports built for engineering, project managers, and the shop floor, plus
formatted exports for third-party inventory software
- CNC machine connectivity to
Microvellum
- CNC tooling setup: router bit
selection matched to materials, and boring head tool layout arranged to cut
machining time
- Manufacturing process consulting
and training
How I work
- Responsive. I answer emails
within 24 hours, usually much sooner. I agree on a schedule up front. If a date
is at risk, I will notify you early, with the reason and a revised date, not on
the day it's due.
- Clear communication.
Questions go out as numbered RFIs, each with a clear problem statement, the
reference sheet, and a specific recommendation so that the reply can be a yes
or no.
- Live review in Bluebeam Studio. Both
parties mark up the drawing set in a live Studio Session, so there's no
emailing PDFs back and forth or tracking which version is current.
- Shop drawings aren't design
drawings. I check the design intent against how the work will be built,
installed, and inspected. One example: on a multi-site retail rollout, I found
that die-wall T-nuts dimensioned on the customer drawings would set the
countertop at 34-3/8", above the ADA maximum. I flagged it with corrected
dimensions before production.
- Detail first, approval second.
I don't rush submittals to get a stamp, since engineering issues are much
cheaper to fix on paper than on the shop floor.
- AWI and ADA. I work in
compliance with AWI Standards and the 2010 ADA Standards for Accessible Design
and follow your shop's standards and processes where you have them. Every
submittal I prepare sets ADA counter and sink rim heights at 33-3/4"
instead of 34", so out-of-level floors don't push finished work over the
maximum, and the cover sheet notes this deviation for the architect and GC.
- Process. If your
engineering department has written procedures, I will follow them. If it
doesn't, I can help put them in place.
Software: Microvellum
Toolbox (AutoCAD or BricsCAD), Bluebeam (Studio). Drawings are delivered as
native DWG and PDF files.
I'm currently accepting a limited
number of new projects. If your engineering backlog is growing or you need
overflow help on a rollout program, email me, and I'll reply within 24 hours.
Peter Turšič
[email protected]
