In the 47.1 library, I'm having trouble figuring out how to add a mid stile to a "drawer front" for a large wall panel. Is there a product that does this easier? I can create it as a door panel with a mid rail, but then I guess I would need to rotate it somehow to get things to look correct. I want to use the door profiles I have in the library so it looks the same as my other cabinet doors with the machining.
