Found a couple of issue with the crown molding this morning. If it is being using and an applied end is on, it turns on the return left. thats correct, but if an adjacent cabinet size is entered that is bigger than the cabinet, it will not turn off the return when it should. it also does not extend by the amount of a filler that has been entered.
