We have had one BHX cnc running for a long time and are now going to set up a BHX 500 (similar but does two mirrored parts at a time). To start I copied the tool file and I will make adjustments as I learn the requirements of it.
Question: with the same tool list why does only the BHX 500 trigger alerts that it is missing a vertical drill for 0.41732" (10.6mm)? I've tried changing the 10.6mm drill diameter a little up and down but no luck.
