Our shop likes mitering panels and solid surface on the CNC with a 0.08" offset and a depth of the Material Thickness + 0.08". This was something that was tested in the past and the shop would like to keep following this pattern. Does anyone have a suggestion as the best way to adjust the mitering tokens in Microvellum to follow this pattern without having to do manual rout lines?
