MODIFING A SAW PATTERN LIKE A NEST PATTERN
So i know you can go into the composite dwg of a nest and "fix" a nest that had a less than desirable optimization, but is there anyway to do this to a saw pattern? So many times i get an optimization that can clearly and easily be fixed or made better but I don't know of any way to go in and manually modify a saw pattern. Does anyone else?
