Modify Subassemblies formulas when adding a new one
Hi. I wonder how I can push the Formulas when i'm adding a new subassembly from the command prompt. I can push the Width, Height and Depth with a formula (=L!Inside_Width). I'm trying to force the Base Point X, Y and Z. I know that I can access those in the Subassembly with Subassembly_X_Origin, Subassembly_Y_Origin and Subassembly_Z_Origin. But I think it's just a one-way push (From the Local table to the Subassembly table).
What I want is:
Subassembly_X_Origin = L!Thickness_Left_Side
Subassembly_Y_Origin = -L!Depth
Subassembly_Z_Origin = L!Toe_Kick_Height + L!Bottom_Thickness
Even if I pass from the Database Explorer to insert the formula, it keeps hard coded value from the standard Specification Group (.64, -23.25, 4.64), or zeros. If I have thicker materials, it won't adjust itself.
