Mulitpass tools - set different options to original tool
I have a multipass tool that uses my main compression cutter. However, I want this tool to have a slower feed and rotational speed to the original tool in the multipass tool. It has the options to change it however the resulting CIX file does not reflect the changes made in the multipass settings and as such runs the tool runs as per the original settings in the tool.
Is it possible to change these setting for the multipass tool only and if so how?
Any ideas or input would be appreciated.
