Multi Select Projects to Move / Delete / Change Status or Use Windows Explorer
In the current setup if you need to move, delete, or change status of several projects, it needs to be done one at a time. Using Database Management can help with deleting but only if you export it first. My suggestion is to have either a multi-select option or at least having ctrl / shift work to select multiple projects. Alternatively having a windows explorer location where creating new folders / modifying location / deleting projects would reflect in MV's Projects list.
