Multi-tool depth
When using a multi-tool, the depth specified in the machine token is ignored, instead the individual tool depths within the multi-tool are used. This system does not allow for the use of formulas or using a multi-tool at different depths - you have to create another one with different individual tool depths.
I suggest that the depths of the individual tools as set in the multi-tool are relative to the depth specified in the token.
