MV Export WO programming logic
I hope this doesn't come across as negative, but I just spent 3 hours clicking the yes button that I'm not getting back.
When you want to export and delete the workorders, it makes you check each on individually.  I can live with that.  But, if you check that you want to delete the WO after export, a little window pops up on each and every work order, to ask you if you want to delete it.  This warning should have been in aggregate, before the delete loop.  In my case (and others I'm guessing), this may be a yearly maintenance item.  Mine was on probably 1500 work orders.  This should have been a simple yes, and let the program do it's thing.
