Hi all, how is everyone handling nest part spacing when you need a larger tool for a thicker or different material? for example I want to use a 1/2 inch compression for 30mm material & 18mm cutter for acrylic, but want to keep the standard gap for our 3/8 cutter for better optimization.
I have created different processing stations but having issues when the guys "Forget" to assign and sort different parts to different stations. Can we please have a nest space setting that looks at the tool diameter + nominal tolerance? Need to take the human error factor out of this! Our last software has always had this facility.
