Nested Parts Offset from Panel Edge
I cannot find the setting to offset a nested part from the edge of a panel. There is an optimization setting in the Nest tab of the processing station call "Small Parts to Center", but it creates an offset relative to the panel dimensions. That is, for a standard 4x8 panel, the offset in the X direction is double the offset in the Y direction. It would be better to have both offset the same or have the control to manually set the offset individually.
