Hello,
Have this fairly basic curved Die Wall that overall is larger than a sheet of 4x8 plywood but if rotated Wall Plates should fit on a 4x8 sheet of plywood. Unfortunately Microvellum Nesting Optimizer refuses to do it and I get no nests.
I maxed out the True Shape without any improvements.
Anyone does what causes the problem and what is the easy fix?
I know the workaround, rotating all parts manually in 2d so it falls below 4x8, but this should not happen.
Thanks.
