Nesting Parts - Centerline Routing
I created and processed parts for a die wall. When I open the drawing with the nested parts, it looks good with the nested parts being cut using Centerline routing. After I create the Machine G-Code for the panel, the Centerline routing becomes Right Compensated routing . I did the same thing yesterday with basically the same parts and the Centerline routing remained Centerline routing after making G-Code. I have not changed the toolfile or the processing station. I tried creating a new work order and a new project and the tool compensation changed again. I tried re-starting Microvellum and my computer, but the tool compensation is still changing. Has anyone else experienced this? Please help.
I am using MV Toolbox OEM 2019 and Build 20.1.617.641
