King Slide SIMLEAD Drawer System Available in the Foundation Library
Microvellum is happy to announce the addition of 32 new pieces of hardware from King Slide into the Foundation Library catalog. From Foundation Library version 23.1114 and onward, users will have access to additional hardware from King Slide's SIMLEAD line of wooden drawer systems: the SIMLEAD wooden drawer slides, made to fit seamlessly onto wooden drawers in client projects.
To access these products, simply select them using the product prompts or Hardware Material Wizard.
Please contact Microvellum support with any questions or issues you may encounter while installing or using.
King Slide SIMLEAD Wooden Drawer Slides
The SIMLEAD wooden drawer slides are full extension, concealed runners created for use with wooden drawers in both frameless and face frame applications. The slides have 8-way adjustability, built-in options for both push-to-open and soft-close mechanisms, and load bearing capacities of 40/60 kg (88/132 lbs.)
Frameless Slide Options:
Hardware typeLoad Bearing Capacities+ Features
Rendering
King Slide 1D85
King Slide 60kg - Undermount - Push Open + Soft Close
King Slide 1D86
King Slide 1E85
King Slide 1E86
King Slide 1F85
King Slide 40kg - Undermount - Push Open + Soft Close
King Slide 1F86
King Slide 1G85
King Slide 1G86
King Slide 1D97
King Slide 60kg - Undermount - Soft Close
King Slide 1D98
King Slide 1E97
King Slide 1E98
King Slide 1F97
King Slide 40kg - Undermount - Soft Close
King Slide 1F98
King Slide 1G97
King Slide 1G98
Face Frame Slide Options:
King Slide 1D85FKing Slide 60kg - Undermount - Push Open + Soft Close
King Slide 1D86F King Slide 60kg - Undermount - Push Open + Soft Close
King Slide 1E85FKing Slide 60kg - Undermount - Push Open + Soft Close
King Slide 1E86FKing Slide 60kg - Undermount - Push Open + Soft Close
King Slide 1F85F King Slide 40kg - Undermount - Push Open + Soft Close
King Slide 1F86F King Slide 40kg - Undermount - Push Open + Soft Close
King Slide 1G85F King Slide 40kg - Undermount - Push Open + Soft Close
King Slide 1G86F King Slide 40kg - Undermount - Push Open + Soft Close
King Slide 1D97F King Slide 60kg - Undermount - Soft Close
King Slide 1D98F King Slide 60kg - Undermount - Soft Close
King Slide 1E97F King Slide 60kg - Undermount - Soft Close
King Slide 1E98FKing Slide 60kg - Undermount - Soft Close
King Slide 1F97F King Slide 40kg - Undermount - Soft Close
King Slide 1F98FKing Slide 40kg - Undermount - Soft Close
King Slide 1G97F King Slide 40kg - Undermount - Soft Close
King Slide 1G98F King Slide 40kg - Undermount - Soft Close
